What Bolt-ons do you have on your Neon?
Old Jul 19, 2007 | 02:09 PM
neonxst05's Avatar
neonxst05
Default RE: What Bolt-ons do you have on your Neon?
Wow, thats a big list. You think I would be able to purchase a totaled out 05 neon and be able to tear it apart to get all the parts I need? Like woulod I be able to put the two cars side by side and transfer the parts?
Old Jul 19, 2007 | 06:40 PM
Exubus's Avatar
Exubus
It would take some work, but if you could find a complete donor car like that, then it would be your best bet $-wise.
Old Jul 19, 2007 | 07:46 PM
AirWolf's Avatar
AirWolf
Im also going to do the 5 speed swap but going the best and only way I would switch from a auto to a 5 speed the srt turbo and tranny swap you get so much more with that swap than a reg 5 speed swap.
Old Jul 19, 2007 | 07:48 PM
lblackneon's Avatar
lblackneon
I have the stuff in my signature along with my perform. mods list.
Perform. mods: AFX Race PCM, AEM CAI, Pacesetter C-back, MPX customized UDP, 60mm MPx Throttle Body, Prothane Motor M. Inserts, Accel 19lb Fuel inj., Vibrant front strut tower bar, Progress Rear Sway Bar, B. bushings, Mopar STS, MSD coil & wires
Old Jul 20, 2007 | 12:59 PM
ryleynoyes's Avatar
ryleynoyes
i just bought this, haven't gotten to drive it yet, but i got a steal on it
Wings West Body Kit
Garrett T3 Turbo
JE Pistons
Nitrous Express
Rims
MSD Ignition
Crane #12 Cams
Eagle Long Rods
Stage 2 Clutch
Crane Spring and Retainers
Intercoolers
Fidanza Cam Gears
Super Sequential Blow Off Valve
SRT 4 Exhaust
Injectors (60psi??)
Prestige Car Alarm
Fuel Pressure Regulator
Double Deck Spoiler
Medium Tube Header
7.5 inch TV
UDP
PT Rockers
Total Seal Rings
Oil Pump
Dropzone Lowering Springs
255 LPH Fuel Pump
PT Lifters
Spw Intake
B&M Short Shifter
Screamin Demon Ignition
Gauges
Semi-Solid Bobble Strut
Main Bearings
Engine Mounts
Clear Tail Lights
Rod Bearings
Hurst T Handle
Front strut bar
[IMG]local://upfiles/55950/B864F31637B64D24BD383B686C790242.jpg[/IMG]
[IMG]local://upfiles/55950/35CCD02A73044A0895EA551C1D692E31.jpg[/IMG]
[IMG]local://upfiles/55950/77AE8DFF9F014CE9907BEC9727F33FF7.jpg[/IMG]
[IMG]local://upfiles/55950/BD83F7642D1044D5AC63659ED124B51E.jpg[/IMG]
[IMG]local://upfiles/55950/664F999F0B654D37B887633A47C87F5C.jpg[/IMG]
Old Dec 13, 2012 | 05:13 PM
ReDRockStar's Avatar
ReDRockStar
bump
got a '95 sport cpe dohc, 5spd, 4whl disc not too long ago. so far got a 52mm TB, intake, rear upper strut tower bar, and I have 8.5mm Crane Firewires coming here soon. more to come. 180 degree stat, UDP, and bobble strut upgrade are next plans followed by a FM ECU
