95 Neon Stalling!!!
Old Jul 24, 2007 | 05:54 PM
tucci1987's Avatar
tucci1987
Default 95 Neon Stalling!!!
I have a 95 plymouth neon highline, after driving it for about 20 mins it will bog and then die out... you can tell wen its about to do this because the car will rev itselfusually at a light or a stop sign and ifyour not holding the brake your going forward. the cam sensor has been changed because that was one of the codes it was showing and now the next one is a timing belt code saying: slipping one or more teeth and another one saying that the ignition coil #1. from these two problems witch of them can be causing this or could it be something else? Also how much does these two problems cost to fix Ballpark.
Old Jul 26, 2007 | 04:15 AM
blondiez24's Avatar
blondiez24
Default RE: 95 Neon Stalling!!!
sounds like a bad coil to me. Thats what mine did when the coil went bad.
Old Aug 9, 2007 | 11:59 PM
mprtftr's Avatar
mprtftr
You may also want to check the crank sensor right above your oil filter.
