engine die'ing out at idle
Old Oct 27, 2004 | 02:14 AM
TJW815's Avatar
TJW815
Default RE: engine die'ing out at idle
then why can u get a neon to idle up a bit if u pump the brakes really fast
Old Oct 27, 2004 | 05:21 PM
casper's Avatar
casper
because 1st the idle will drop, then when the PCM sees that the idle is dropping cause of load, it will pick up the idle to handle the load, my car does the same thing at idle with the stereo volume up, I have a few amps.
Old Oct 29, 2004 | 11:34 PM
dimst_oner2000's Avatar
dimst_oner2000
is there an adjustible screw on the newer neons?and if so which way to turn it to make it idle higher
