Dodge NeonThe sport compact car that took the world by storm. the Dodge Neon. Depending on the trim level you get, this sporty ride has something to offer everyone.
one more question, when any of you guyz turn your car (se) on does airbag and check engine light come but dont blink, cause they both come on for like 5 sec that is it
Yes, I believe that is right. My check engine like comes on for about 5 seconds that goes away. I would have to double check to be certain but I'm pretty sure it does. So you swapped clusters? If so, did it idle fine before?
I took a look at mine and I've noticed that when I first start up in the mornings, it will idle at around 1000 RPM's. Then after I've been driving for a while and the engine has heated up it goes down to about 500. However, if I have the heat or the ac on then it will be anywhere inbetween the two, never more, never less.
Yep, thats what mine does. Except mine drops to 800...not 500. I have a manual so that could be the difference as to why yours idles at 500 and mine is at 800.
Yes all those lights come on, It is probably running the self check when you start your car, so far all the cars I have owned, those lights come on. And if I rememebr even the oil light and brake light comes on as well.
