2 more questions weeeeeee
Old Nov 5, 2004 | 09:33 PM
ZeroTo60in30's Avatar
ZeroTo60in30
Default 2 more questions weeeeeee
how do i go about doing the srt4 front end swap?
and...
can i swap a 1st gen dohc into a 2nd gen?
thanks a lot
Old Nov 6, 2004 | 12:17 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: 2 more questions weeeeeee
The front end swap no clue.
And yes, you can put a 1st gen engine in a 2nd gen.
Old Nov 6, 2004 | 02:05 AM
LowSlowNeon's Avatar
LowSlowNeon
You can...but its a PITA. I looked into it. Its more work than its worth unless you have free parts.
Old Nov 6, 2004 | 02:52 AM
Cr@zy Squ33
It's not any more difficult than doing an engine swap on a 1st gen.
They are pretty much the same engines.
Old Nov 6, 2004 | 03:33 AM
LowSlowNeon
Good luck getting the sentry key to work with a first gen.
Old Nov 6, 2004 | 03:58 AM
Cr@zy Squ33
I don't see why he'd have an issue. My buddy's 2k has had it's engine swapped a lot and it's got the sentry key.
Old Nov 6, 2004 | 04:13 AM
LowSlowNeon
And which pcm did he use?
Old Nov 6, 2004 | 04:45 AM
Cr@zy Squ33
Stock.
He did end up doing something stupid one time and ruined the PCM, but that was a completely different scenario, I think he was trying to bypass the sentry but found it didn't work.
Old Nov 6, 2004 | 04:47 AM
LowSlowNeon
Okay...was it a dual cam or single cam first gen? Dammit...it posted before I was done. But...did he swap a sohc or dohc head on it. I was lookin at the dohc head swap...but my sohc pcm wouldn't really take advantage of it...and I couldn't find a way around the computer problem/sentry key. So I'm keepin it sohc...
Old Nov 6, 2004 | 04:55 AM
Cr@zy Squ33
Why does that matter? You can put a 1st gen engine into a 2nd gen.
It was an R/T engine.
