PCM Testing
Old Nov 7, 2004 | 02:18 AM
raviaan's Avatar
raviaan
Default PCM Testing
I believe the 97 has the self diagnostic... I tried the turn the key thing about 5 times (just to make sure I wasnt doing something wrong)... I get nothing... not even a 12 or 55... so could my computer be dead...?
I have a no start problem right now... I have crank, spark and fuel... no start...
Thanks
Raviaan
Old Nov 7, 2004 | 03:52 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: PCM Testing
Nope, nothing is wrong witht he computer. You probably aren't doing it correctly.
ON-BOARD DIAGNOSTICS
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition for a neon.
CODE Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Rad Fan control relay circuit
37 Torque converter clutch solenoid CKT or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
46 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
Old Nov 8, 2004 | 06:26 PM
raviaan's Avatar
raviaan
When I put the head back in, it started right up. Shortly after there was a slight squeel from the cam gear side of the motor, and then it started taking like 15 seconds to start. I thought the car was out of time and pulled the cover... and the marks were fine, but someone brought something to my attention, maybe the pin on the cam had snapped... then the bolt tightened the gear all the way to the cam (causing the squeel by rubbing the housing) but before it tightened completly, it had shifted a few teeth worth of timing. Is this somthing anyone else sees as possible? (before I start tearing stuff apart again)
Raviaan
Old Nov 8, 2004 | 09:18 PM
casper's Avatar
casper
If you heard a squelling, I would pull the valve cover and take a look, its really not that hard to do. Make sure the cam gear is line up right.
Old Nov 9, 2004 | 02:30 AM
raviaan's Avatar
raviaan
I'll pull the valve cover. I checked the timing marks and they are right on. What I am talking about though would not affect the timing marks. They would still line up perfectly. If the Alignment pin on the camshaft snaps, it would allow the gear to spin a little before the bolt finally tightens all the way. Therefore making the timing off, but the marks would be right on. I a, having the car towed to my house on friday... once I figure out what it is, I'll let everyone know. If anyone else has any more idea's let me know.
Raviaan
