stock 98 r/t 2 door... questions need answers
Old Nov 14, 2004 | 01:56 PM
mhike's Avatar
mhike
Default stock 98 r/t 2 door... questions need answers
i myself just acquired a virtually stock 98 neon r/t... thing is i want to add some serious hp but the original motor has 160 thousand miles... with that mileage im afraid something may go wrong... so what do u all think... should i raise the money to rebuild both top and bottom end or are there ways to check if everything is fine on the motor and otherwise ok to start buyin the basic bolt-ons to set up for the modernperformance turbo stage 2 package... what do you all think...
Old Nov 14, 2004 | 03:02 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: stock 98 r/t 2 door... questions need answers
Direct your attention here: https://dodgeforum.com/m_104622/tm.htm
Old Nov 14, 2004 | 11:33 PM
casper's Avatar
casper
yeah no problem with the milage. Mild boost and you will be fine 8-10PSI. Go much higher than that any you are going to need to rebuild the bottom end of the motor if it only had 5 miles on it the bottom end will hold 300HP. And any turbo that you put on you almost have to do the cam, and after the cam the rest of the top end is not that expensive to do and for simplicity issues just should be done.
Old Nov 15, 2004 | 01:43 PM
mhike's Avatar
mhike
yea well your right about the bottom end, its deffinetly at the top of my list but what about the pistons, should i get the low compresion so itll be ready for turbo setup or should i stick with the high compresion until i get the turbo? oh and you had mentioned something about the cam... which cam would you recommend for the turbo setup from hahn stage 2? oh and one more thing what is an egr valve and something about cutting it off for an increase in horsepower... any ideas from anybody... please respond...
mhike's Avatar
mhike
Old Nov 15, 2004 | 08:51 PM
Cr@zy Squ33
Low compression.
