98 Dodge Neon i need some help
Old Nov 7, 2007 | 12:19 AM
Trajik1's Avatar
Trajik1
Default 98 Dodge Neon i need some help
My girlfriends car broke down on her, the timing belt broke and they think the valves might be bent, anyway to check without taking stuff off? and also whats the cheapest way to fix this? its got 80,000 miles
any and all help is appreciated thanx! [>:]
Old Nov 7, 2007 | 01:25 PM
spudsterier's Avatar
spudsterier
Default RE: 98 Dodge Neon i need some help
only way to check if there are bent valves is to either take the head off or replace the timing belt and then do a compression test....
most likely it does have bent valves
