2001 Neon, 03 light, front..
Hi I saw that someone did a conversion by taking an 01 Neon putting 03 lights and an SRT front on.. I was wondering will the lights fit fine, like bolt in like the stock ones do? If they do can I then install a bumper made for an 03 neon.. Reason being I wanted to use the 03-04 turbo front from Kaminari because of the foglights plus I like the signal being right inside the headlight housing too...
I'm not sure the newer 03+ headlights would fit because if you go to moderns site and look for new headlights they have some but they say they fit 00-02 neons and will not fit 03+ neons. I'm sure you could mod them somehow to get them to fit, they look very similar in shape and size to each other, but I think there is a slight difference.
http://www.modernperformance.com/dcx...adlights.shtml
^^That is what I'm talking about. Hope that helps you.^^
Oh silly me...I didn't read the rest, if you can get the Kaminari to work the lights should to, I've seen the 03+ lights on neons with the Kaminari bumper.
http://www.modernperformance.com/dcx/ip2_cf_hood.shtml
^Kaminari bumper^
^Kaminari bumper^
Yeah...you may have better luck browsing some posts over on neons.org or contacting Kaminari directly on fitment. As for the seats I would check ebay or SRTforums.com is a good place to look for them.
http://www.neons.org/forums/viewtopic.php?t=194828
Look there for SRT4 seats. I found it browsing for parts.
If you can get the bumper to fit you should be fine. It may take some playing with and ajustments. The only problem that I can see would be the fitmant to the fender, the lights should fit right it with the hood and bumper.
Hi it should work... According to places that sell fenders and hoods they will fit.. On ebay fenders say for year 2000 to 2003 and so does hoods, and the lights look the same...
