95 Dodge Neon HELP!!
Old Nov 20, 2004 | 11:29 AM
xprettylilmommyx's Avatar
xprettylilmommyx
Default 95 Dodge Neon HELP!!
I have a 95' dogge neon automatic. I went in 3 months ago and had my oil changed along with my transmission. Well this morning on the way to to work, it started skipping. I would stop at a red light and when I tried to go the car stalled so I had to hold my foot hard on the gas. It did not do it everytime just sometimes. My husband put in 1 quart of fluid last night because he has noticed the same thing yesterday...any ideas? Im gonna have him look when I get off work today and make sure it is not out of fluid.
Any Ideas are appreciated, I hate driving it like that.
Monica,
Old Nov 20, 2004 | 11:38 AM
GroundControl's Avatar
GroundControl
Default RE: 95 Dodge Neon HELP!!
did you put in the right transmission fluid. there is atf 3 i think and atf 4 or just plane atf see what ur car needs and make sure u put the right one in.
Old Nov 20, 2004 | 02:51 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
You are going to need Chrysler approved ATF fluid, (7127) I'd suggest only using Mopar transmission fluid. You can use ATF3 or ATF+4 (synthetic).
If you took it to a garage that did not know this I suggest going to the dealer, picking up new fluid and a filter kit taking it back tot he garage that did the work and have them redo the work free of charge. And while they are at it they might as well flush the transmission and make sure they didn't screw anything up.
Also, are you throwing any codes?
Heres how to check:
ON-BOARD DIAGNOSTICS
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition for a neon.
CODE Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Rad Fan control relay circuit
37 Torque converter clutch solenoid CKT or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
46 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
