this is for u tech guys...
hey if i decide to go all motor which compression do u recomend and which cam can match that compression... i.e. 12-1 then maybe through in a 18 drag cam or what... or do i have this all wrong...? help...
If you want a more streetable car get 10.5:1 comp. with crane 18's. If you are willing to do some extra work, go for a 12.5:1 comp. , P&P head, and crane 18's or larger.With that you can still be streetable, but you will also need 24lbs. injector, and an S-AFC, and some tuning to run on pump gas. Whichever way you go, I strongly recommened an S-AFC, just to help the car idle, and run efficient.
