Please help!!!
Old Mar 12, 2008 | 12:43 AM
Lopro's Avatar
Lopro
Default Please help!!!
I have a 2002 Neon SE. The problem I’m having is when the car was parked last night it was running fine. Today I go to start it and it has a hard time starting, and when it is running, it runs very very very rough. There is also a strange noise coming from the Idle Air Control when the ignition is in the ON position. Its a constant beep or buzz sound like beeeeeeeeeeeeeeep sound and stays buzzing until the ignition is tuned back to the OFF position. I have never heard that buzzing sound come from it before. Could this problem be the Idle Air Control?
Old Mar 16, 2008 | 08:07 PM
kabuk1's Avatar
kabuk1
Default RE: Please help!!!
Is it throwing any codes? To check codes, if you don't already know how- put your key in & turn the ignition to on-off-on-off-on-off, 3 times in succession withOUT starting the engine. Any trouble codes will appear where the mileage is. Report back with any codes it gives you.
Old Mar 17, 2008 | 08:28 PM
Lopro's Avatar
Lopro
Yep kabuk1, it show P 0508 code. I referenced it and its something to do with the Idle Air Control. Im going to replace it and see if that takes care of it.
