Rear Disc Brakes
Old Mar 21, 2008 | 04:47 PM
AlyssaN's Avatar
AlyssaN
Default Rear Disc Brakes
Hey I was wondering if you can put rear disc brakes on a neon es and if so how expensive is at and can it be done on your own?
Thanks for the help
Old Mar 21, 2008 | 04:59 PM
inthewerks's Avatar
inthewerks
Default RE: Rear Disc Brakes
yeah you can do a rear disc conversion. you need the srt-4 hub/knuckle asembly, caliper, brake line to do it. cheap from a junk yard.
Old Mar 21, 2008 | 05:33 PM
03neonRT's Avatar
03neonRT
Or you can use the rear brakes from a Neon R/T, 2nd Gen Neon w/ rear discs, 1st Gen Neon w/ rear discs, or the PT Cruiser.
Old Mar 21, 2008 | 06:24 PM
inthewerks's Avatar
inthewerks
yes. my fault. its just that so many people want to know if srt parts swap into the non turbos that im stuck in that mode.
Old Mar 22, 2008 | 12:40 PM
12 volt's Avatar
12 volt
yes it can be done on your own , not idea what they usually go for.
If you have a first gen your not going to see any benefit from going to rear discs, other than better looks and easyer maintenance. Of couse im talking about the first gen rears, no idea if the others are better.
https://dodgeforum.com/m_682777/tm.htm
personallyi just broke one of my rear spindles going off the track in to a ditch. so i have a drivers side if your what to buy it cheap
Old Mar 27, 2008 | 10:34 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
and if u get a wrecked rt neon (2nd gen) they r the same spindles asthesrt spindles just fyi
Old Mar 31, 2008 | 09:27 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Any neon with rear disc will swap over. 1G or 2G.
