HELP 1995 DODGE NEON
even if you check light isnt on it still might throw some codes
Q: My Check Engine Light (CEL) is on, what do I do?
A: To read any codes on your neon, put the key in the ignition and cycle it to ACC on-off-on-off-on within 5 seconds. As the CEL flashes, count the number of flashes. This represents the code. An example would be flash-flash-flash-flash, pause, flash-flash-flash, which would be a Code 43, single or multiple cylinder misfire. A list of codes can be found HERE or HERE.
i have a 1995 dodge neon that ate the timing belt while on the freeway... i just pulld out the engine and tranny and replace both since a friend had one with about 60,000 miles on it every thing fit just had to swap out the crank sensor cam sensor now i have no spark...and low voltage going to the coil pack. the engine and tranny were out of a 1996 does that matter? i am thanful for any help!
Did you also swap over the wiring harness and PCM? The 95 harness and PCM is different than the 96, 97-99 ones.
