power side mirrors?
Old Apr 17, 2008 | 01:32 PM
dehahn1984's Avatar
dehahn1984
Junior Member
Default power side mirrors?
this is a quite confussing thing for me. my power mirrors do not work, i took the plastic off the inside of the door and there is one connection to the controller for the mirror. now, the wires from the conector run directly into the mirror and thats where they end. now unless my frickin mirror is battery or solar powered, this must be my problem. considering there is no power supply for the mirror, im confused, is there a connection for the mirror that should be there but isn't? these mirrors are stock power mirrors on my 96 neon sport. any ideas?
Old Apr 17, 2008 | 01:55 PM
12 volt's Avatar
12 volt
Default RE: power side mirrors?
there is a connector under the door panel, i belive is four wires.
do you have the controler switches by your window? Maybe someone added the power mirrors without the wiring.
Old Apr 17, 2008 | 02:14 PM
dehahn1984's Avatar
dehahn1984
Junior Member
yes, there is a switch and connector under the door panel, four wires. this connector though, with the four wires, runs directly into the mirror, and thats where it ends. its not connected to anything than just the mirror.
Old Apr 18, 2008 | 08:56 PM
dehahn1984's Avatar
dehahn1984
Junior Member
no info?
Old Apr 19, 2008 | 03:16 AM
12 volt's Avatar
12 volt
dont know what to tell you.
there sould be a connector there with the same color wires that are coming out of the mirror
