plug wire broken HELP
Old May 26, 2008 | 10:01 PM
A_White's Avatar
A_White
Default plug wire broken HELP
Hello dodge onwers, I was changing plugs in my gf's car (2005 neon sxt 46,000 mi), and when I got to the #2 plug I couldn't get to the socket on it.Upon closer inspection I see that part of a prior wire is stuck around the base of the plug, the ones that are on it are MOPAR but the #2 doesn't look torn but I wouldn't think it can make good contact.I'm lost on how to get it off to change the plug, (long pair of needle nose?). Also all autozone, and advance had for wires was the cheap ones. What kind should I use, I got NGK v-power plugs at .035 gap. I am having to use the old mopar wires until tomorrow, will this beok to drive.It runs the same as before now, but the #1 and #2 wire are pushed down further than they were before. Changing plugs and wires shouldn't be this hard.
Any help please I'm in a bind.
Thanks in advance
Old May 26, 2008 | 11:52 PM
N30N's Avatar
N30N
Default RE: plug wire broken HELP
i did the same thing but it messed my wires up bad so i just went with ngk-v power and autozones duralast wires.they rungreat with the ngk's and they should be around 20 bucks.i had to use a neddle nose to get the coil off to so good luck with that man.lol and welcome to the forum!![8D]
