engine light
Old Jun 14, 2008 | 09:40 AM
Freeagentrider91's Avatar
Freeagentrider91
Default engine light
sucked some water into my engine through my cold air intake. had a large power loss. changed my oil and its perfect now but the light is still on and annoying.
code is 1 2 4 3 5 5 (on off on off on method)
how do i turn it off?
Old Jun 14, 2008 | 10:48 AM
spec_ops57's Avatar
spec_ops57
Default RE: engine light
Did you reset the PCM?
Old Jun 14, 2008 | 11:31 AM
Freeagentrider91
no
how do you do that?
Old Jun 14, 2008 | 11:45 AM
spec_ops57's Avatar
spec_ops57
Take the negative terminal off your battery, then depress your brake to completely drain the power, and hold for about a minute.
Hook it back up and you should be good to go..
Old Jun 14, 2008 | 12:08 PM
Freeagentrider91
yeah i called a auto shop and thats what they told me so i did that and it worked perfect
thank you
Old Jun 14, 2008 | 01:38 PM
spec_ops57's Avatar
spec_ops57
Do you know what "Code 1 2 4 3 5 5" meant?
Or are you sure that's not your mileage?
Old Jun 16, 2008 | 03:01 PM
Freeagentrider91
i know what i'm taking about dumb ***
a code error 43 is a misfire
Old Jun 19, 2008 | 12:01 PM
spec_ops57's Avatar
spec_ops57
Take er easy now lil guy, I'm just making sure..
Old Jun 19, 2008 | 04:59 PM
Freeagentrider91
sorry man
Old Jun 20, 2008 | 03:27 PM
reppinthe202's Avatar
reppinthe202
the easiest way is to take the fuel pump fuse under the hood out for a few minutes
it worked for me cuz i had code 43 from a ****ty spark plug wire
