Headlight trouble. A short perhaps?
check contacts and wires in "start" push-button, also check for broken solder connections there.
OR you could set up a jumper wire at the plug-in connector for right handlebar switch ( after referencing wiring diagram) to remedy the problem IF the problem is in that switch.
_____________________________
Check out: Autopartswarehouse.com
yeah i've been having a problem with my headlights since i bought it....i use my brights at night but my lights i guess are all dirty so they look regular lol
thats why i never got caught i guess haha
but my fuses are good cus i checked them several times...could i need new lights or something??
how much wud it be too ?!?
help!
help!
If ur fuses are good and your lights do work from time to time, I suggest that you have a 12V power wire running to the light that is grounding itself out from time to time, or has a weak connection in the switch... just barely... that will rise the current in the wire and light bulb, making it fry out too quick.
i actually got my car cleaned inside and out today and got my headlights cleanes..good Lord they were dirty but my reg. lights didnt work so again i had to use my brights on my way home from the mall...i guess i need new bulbs?!
