manual transmission noise
Old Aug 9, 2008 | 03:17 AM
wHipPrOper3's Avatar
wHipPrOper3
Default manual transmission noise
for a while now theres been a noise coming from my transmission when the a/c is on..a rattling knocking i guess. so i had the release bearing replaced and that helped improve shifting but not so much the noise...i had the clutch and both cylinders replaced not too long ago and can't figure out what's causing this issue. my pedal pressure also isn't as great as it used to like something when wrong at some point.
could it be the flywheel? cuz i didn't replace it when i got the clutch which i think was Modular(whatever that means) or the hydraulic hose? this is really bugging me! im deciding between either getting a new transmission, rebuilding this one(even though it runs fine) or replacing the clutch again with a new flywheel this time or just the flywheel.....
