over heating problem
Old Feb 28, 2005 | 08:19 PM
smitty1's Avatar
smitty1
Default over heating problem
I need some help... When the car is moving the temperature gauge reads fine. when I stop at a light or stop sigh it starts to overheat. Then when i start going again it goes down. I changed the thermostat, had the water pump replaced in the last week so fluid is good. I also made sure the fans are working. After having the water pump replaced it didnt do it for about a week and it has done it 2 times today feb 28... if anybody know why it is doing that or what to check next please let me know thanks
Old Feb 28, 2005 | 09:22 PM
y2neones's Avatar
y2neones
Default RE: over heating problem
make sure the fan behind the radiator is working
Old Feb 28, 2005 | 09:25 PM
casper's Avatar
casper
I would think it would be the fan or low coolant. It is normal for it to go up a slight bit but not a lot.
Old Feb 28, 2005 | 10:55 PM
casper's Avatar
casper
If its overheating at a stop and not when your moving, its either: clogged radiator, bad thermostat, water pump, low coolant, or a bad fan or fan sensor. Thats really all it can be
Old Mar 1, 2005 | 01:17 AM
y2neones's Avatar
y2neones
yeah in one of my old cars i had that same problem, it ended up being the motor in the fan. once i replaced that it fixed it, kinda... that car had alot more problems than just the fan. but that is def something to check
Old Mar 2, 2005 | 06:48 AM
ewetho's Avatar
ewetho
Yup check the fan because you loose airflow when stopped. Clean you raditor too. If you have A/C then check between the A/C condensor and the radiator too. Whe it is starting too get warm turn on the A/C and see if that lowers the temp If so then would definitely check your primary cooling fan n back of radiator. Most likely source of a problem.
