slight problem...
Old Mar 10, 2005 | 09:34 PM
jonbonazza's Avatar
jonbonazza
Default slight problem...
ok well i got my car back from the shop wednsday and this morning i pulled out of the driveway to go to school.. i backed out and put it in drive.. then it happened... transmission slippage... thats right, when i put it in drive it acted as if it was in neutral after about 20 sec of reving the engine it kicked in and i had no more trouble... that is until after school when i went to go home IT HAPPENED AGAIN!!! i have a feeling its the pump seal... any ideas??
thanks,
Jon
Old Mar 10, 2005 | 09:38 PM
morningpride's Avatar
morningpride
Default RE: slight problem...
Check to make sure the trans is full of fluid, if the level is low, your trans will not engage properly!
Check it at idle w/ the engine running, after it has warmed up.
Good luck!
Old Mar 10, 2005 | 10:50 PM
jonbonazza's Avatar
jonbonazza
thnx man its late here so ill do it when i get home from school tomorrow
Old Mar 11, 2005 | 06:41 PM
jonbonazza's Avatar
jonbonazza
i checked the tranny fluid and it was low... so im assuming thast the prob.. but i have to go to work b4 i cna change it cause we are out of fluid and... yea dont really have time to pick some up =(
