Stupid Question
Old Mar 14, 2005 | 03:41 AM
jon92860's Avatar
jon92860
Default Stupid Question
How do you remove the spark plugs on a 2003 Neon ???? I am new to my car, and have yet to know more about it .... sorry ....
Old Mar 14, 2005 | 08:33 AM
jonbonazza's Avatar
jonbonazza
Default RE: Stupid Question
well.. lets see.. you take off the plug wires and put a socket wrench with a spark plug socket in and un srew them then put the new spark plugs in and put the plug wires back on... make sure when you put the new plugs in u only screw in abot 3/4 turn o and make sure they are in strait.. if something breaks your in for some trouble if it gets into part of the engine... u might be lucky and be able to get it out
Old Mar 14, 2005 | 10:11 AM
watben58's Avatar
watben58
if i can take the liberty to add this. Before removing the spark plug cables, take in notes order to replug it correctly
Old Mar 16, 2005 | 03:32 AM
casper's Avatar
casper
ORIGINAL: watben58
easier is just to do one at a time.
Old Mar 16, 2005 | 11:02 AM
chud298's Avatar
chud298
Also I don't know if any of you know this, but when you put the wires back on you should do a thing called burping it. Take a zip tie and put it inside the wire. Put the wire on with the zip tie still in. Once the wire is on all the way take out the zip tie. This is to make sure the wire won't pop off on you
