Flasher problems
Old Mar 18, 2005 | 12:34 AM
watben58's Avatar
watben58
Default Flasher problems
Yes i know i have a lot of small problems. Here's another one. I use the left or right flasher and after i've turned the flasher continue to flash. The steering don't do his job i think. Do you know what's wrong ?
Old Mar 18, 2005 | 02:58 AM
RayDog26's Avatar
RayDog26
Default RE: Flasher problems
prolly the turn signal switch is bad.. can get one at a junk yard cheap.
Old Mar 18, 2005 | 10:03 AM
watben58's Avatar
watben58
Is it easy to find ? it's under the cover just beside the steering ?
Old Mar 18, 2005 | 02:30 PM
matt_guiver's Avatar
matt_guiver
i have that same problem for ayear now and im used to it now. its just a dodge!!!!!
Old Mar 18, 2005 | 05:26 PM
RayDog26's Avatar
RayDog26
yes usually its right below the steering column cover.. i never took mine off but i did on other cars and thats how it was.. they aren't that hard to do..
is the problem like when you have the steering wheel turned some and u go to put on ur turn signal it does go ?? because mine does that some times but its normal.
Old Mar 18, 2005 | 07:58 PM
watben58's Avatar
watben58
At the dealer they told me they need to remove the steering and also apply a airbag procedure ??????????????????
Realy ?
Old Mar 18, 2005 | 08:53 PM
RayDog26's Avatar
RayDog26
ur not removing any thing to do with the steering ur just taking the panel off around the steering column. also to be safe because there is an airbag unlug the battery and wait 15 mins for the air bag battery to turn off. this way if some thing sparks or some thing the air bag won't go off in ur face.... its very very rare but thats why they are called accidents..... better to be safe then sorry.
but before u do that what exactly is the problem ?? is it what i said above ??
Old Mar 18, 2005 | 10:13 PM
watben58's Avatar
watben58
I need to change a part call multifunction switch. That's all. When finish to turn the flasher don't stop automaticly
Old Mar 18, 2005 | 10:34 PM
RayDog26's Avatar
RayDog26
then yeh its prolly the switch. you can get one at a junk yard.
Old Mar 18, 2005 | 11:01 PM
watben58's Avatar
watben58
Hey thank's a lot man. I'll take a look at it this week end cause it's realy unpleasant
