Speedometer
Old Apr 7, 2005 | 01:29 PM
DodgeDog's Avatar
DodgeDog
Default Speedometer
97 Neon Sport with 162,000 miles. Yesterday my speedometer needle started jumping around until it just stopped working. Today it worked fine for about 35 miles and again jumped around until it stopped working. When it went crazy yesterday it was during a major rain storm.
Does anyone have any easy fix ideas!
Old Apr 7, 2005 | 08:00 PM
matt_guiver's Avatar
matt_guiver
Default RE: Speedometer
try replacing the speed senser.
Old Apr 7, 2005 | 10:58 PM
DodgeDog's Avatar
DodgeDog
Where is it and is it easy to get at?
Old Apr 7, 2005 | 11:32 PM
SlowAssNeon's Avatar
SlowAssNeon
its not to hard to get to really.. its located on the trans.. youll have to remove the battery and battery tray to get to it i do believe.
Old Apr 8, 2005 | 09:58 PM
casper's Avatar
casper
Its either the speed sensor or its the typical bad gauge cluster.
Old Apr 9, 2005 | 04:48 PM
alphasonic210's Avatar
alphasonic210
I have replaced my VSS and my speedo works when it wants to you should not have to remove anything it is located towards the back of the tans on the drivers side it has two wires on it that you will have to cut and splice a new harness on it. the only thing is if you still have your stock air box you will have to remove it to get easy access to it.
Old Apr 10, 2005 | 08:17 AM
RadarLove's Avatar
RadarLove
Usually it's just the pin either on the cluster itself or the jumper that needs to be resoldered. There are how-to's floating around. Try neons.org if it isn't pinned here somewhere.
Best of luck!
Old Apr 10, 2005 | 01:41 PM
casper's Avatar
casper
I can't link it right now from this computer for some reason, but look at the top of the page in the 1st gen neon forum, and you will see the picture of what has to be soldered.
Old Apr 11, 2005 | 05:00 PM
DodgeDog's Avatar
DodgeDog
My neighborhood mechanic says its not the cluster. He says its the speed sensor because the cruise control is also cutting out when the speedometer goes. He says the cruise needs a speed reading to function properly and a problem at the dash board wouldn't cause the cruise to cut out. Does this make sense? And, do I really have to splice in a new speed sensor?
Old Jul 23, 2006 | 10:56 PM
Allnbrgdn's Avatar
Allnbrgdn
good question, can someone answer this please!!!!!!!!!!!!
