Help car wont start! (alarm troubles)
Old Dec 22, 2009 | 09:18 PM
NeonFTW!'s Avatar
NeonFTW!
Default Help car wont start! (alarm troubles)
so today i left my lights on by accident and killed the battery(accident) in my 96?? neon and when the battery died i found out that my car had an alarm installed wich i did not know about because the previous owner (my grandma) had lost all the clickers for it. so my alarm goes off now every time i open the door but i thought no big deal ill get a jump buy a new battery and it wont be a problem so i got someone to jump my car but the problem is now because the alarm has been set off and i have no way to deactivate it even though there is power now in the battery the car wont even turn over because hte alarm has disabled it. so i have no clue what to do can anyone suggest anything?
Old Dec 24, 2009 | 03:09 PM
Racersteve's Avatar
Racersteve
This shouldn't be too hard.
Pop the front of the dash, 2 screws at the bottom and one on the side.
Remove the metal plate under the dash, 2 more screws.
Look at the wires coming down from the ignition switch, there should be a
thick yellow wire that is cut. Each end of that wire goes to the alarm,
connect the 2 ends of the yellow back together.
Find the control box fo rthe alarm and unplug it.
You should be good to go.
Steve
