41TE help - 5 codes pulled
Old Aug 3, 2010 | 11:09 AM
xattax's Avatar
xattax
Default 41TE help - 5 codes pulled
I have a 2002 Dodge Neon ES, 2.0L with 41TE auto trans. The trans will work for a short bit cold and then start whining and you pretty much have nothing but neutrals. I pulled the codes and they are, p0736, p0846, p0841, p0992, and p0700. I have been researching these codes and I suspect that the solenoid pack may be faulty, but at the same time I noticed that the trans appears to be overfilled with fluid. Would an overfilled trans be a possible cause to these DTCs? Any and all help is greatly appreciated. Thanks...Joe
