98 Neon 2 Door. DOOR PANELS
Old Aug 19, 2010 | 08:40 AM
linkmaster6's Avatar
linkmaster6
Default 98 Neon 2 Door. DOOR PANELS
Hi there,
Just wondering if someone would be able to tell me how to take a door panel off of a 98 Dodge Neon 2 door.
Thanks in advanced, pics would be great
Old Aug 21, 2010 | 12:02 PM
hemi4spd's Avatar
hemi4spd
1. open door, lower window, remove door pull cup, While pulling door handle remove screw securing trim panel to door from behind inside door relase handle
2.being careful not to scratch the paint Use a trim tool (slot screwdriver will do) to disengage securing clips around perimeter of door panel (dont be afraid they just press in and if they do break they are easily changed) tilt panel outwards from the bottom to clear any locator pins the panel hooks over top of door.
3. move panel aside a bit to disengage the clips holding the door linkages, unplug any wiring for power locks or windows.
4 Remove panel from car completley
5. installation is reverse of removal
