Fuel pump works but my car isnt sending power to it
Old Dec 1, 2010 | 01:12 AM
Mrsa's Avatar
Mrsa
Arrow Fuel pump works but my car isnt sending power to it
Ok, I have a 95 dodge neon SOHC Base. First off i stalled out while in idle. Came to the conclusion it was something related to the fuel pump. so i took the fuel pump out and hooked it up to the battery it worked fine. hooked it back up to the car and got nothing. i checked the fuses and the relay, I even replaced the cable that plugs directly to the fuel pump module. And also after i replaced the relay it primed three consecutive times and started up, then stalled. After that i got it to do it a few more times on and off and now it doesnt work at all again. Im not really to car savvy so any help or suggestions would be greatly appreciated.
Old Dec 1, 2010 | 11:31 AM
bg1995redneon's Avatar
bg1995redneon
Check the auto-shutdown relay and also check the PCM to see if there are any error codes being spewed. You can get a free readout of the 4 digit error codes at almost any parts store, or you can do the Dodge key dance and check the 2 digit blink codes (looking at the check engine light on the dash). Ignore 12 and 55.
Old Dec 1, 2010 | 05:52 PM
ALLDATAdiyINFO's Avatar
ALLDATAdiyINFO
Former Vendor
Are you getting fuel at the fuel rail?
Is the pump picking anything up?
