Spark Plug Gapping
Old Jun 27, 2005 | 07:53 PM
PAGODA's Avatar
PAGODA
Default Spark Plug Gapping
hi again all,
i wanted to ask another question. i was thinking of replacing the Spark Plugs in my Neon. what do you think of the V-Groove and Platinum Types? do they work? also shall i Gap the SparkPlug or just Install them and don't worry/bother to?
thank you once again
DAN
Old Jun 27, 2005 | 10:48 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: Spark Plug Gapping
you should always gap them b/c the diff can be major and affect the performance of your car. If your talkin bout the spitfires they can be used and do their job well, however, unless you are building a drag only car, they arent recommended cuz they get so hot they separate from themselves and can deteriorate parts in your engine. Platinums dont work in your Neon at all. Just buy NGK or autolite or champion spark plugs they get the job done.
Old Jun 28, 2005 | 07:29 AM
RadarLove's Avatar
RadarLove
Good copper plugs gapped properly always give the best results in stock or lightly modified Neons. High power (350+ HP) turbo guys tend to go with Denso Iridiums at a lower temp rating.
Best of luck!
