2002 Dodge Neon help please
Old Apr 21, 2011 | 12:02 AM
shadowfires2448's Avatar
shadowfires2448
Default 2002 Dodge Neon help please
Ok this may sound aliitle backwards. The coolant Reservoir bubbles after i cut the car off, it at no time runs hot past 185. it has a new thermostat in it, and fresh coolant. Both fans do work AC blows cold. Is there a reason why the coolant Reservoir bubbles, but the car has never at anytime run hot? There is no oil in the coolant when it was changed or now. Oil was changed and all looked good. I am really confused.
Thnak you.
JW.
Old Apr 21, 2011 | 12:07 AM
atthewmartin114's Avatar
atthewmartin114
radior cap is stuck
Old Apr 21, 2011 | 11:20 AM
darthroush's Avatar
darthroush
Section Moderator
Most likely a bad radiator cap, either the cap itself or the gasket. Mine did this when I first bought it. Half of the gasket was missing.
Old Apr 22, 2011 | 01:22 AM
shadowfires2448
Thank you new cap problem solved. Great help here.
