Can't find corrent dash LED lights.
Old May 11, 2011 | 05:30 PM
mikeeey's Avatar
mikeeey
Default Can't find corrent dash LED lights.
I've read around found that the neon uses pc194 bulbs to light the dash, so assuming it was the same thing, I ordered some 194 blue led's from ebay. yesterday when they arrived I was excited to swap them all out, and I found they are different sized bulbs.
I'm having trouble trying to find blue led's that can replace pc194 bulbs.
Here is what a pc194 looks like:
at the base of the bulb the plastic has notches that you can just twist it into the back of the dash.
The closest I was able to find are these 509t bulbs:
http://www.m-99.co.uk/Car_Neon_LED_L...led_bulbs.html
I'm just hoping I don't purchase the wrong size again.
Is anyone familiar with swapping the dash lights with LED's?
Thanks!
Old May 11, 2011 | 10:17 PM
darthroush's Avatar
darthroush
Section Moderator
Some 2005 Neons had the bulbs soldered into the base. You need to get new bases from a Dodge dealer, online or out of a pre-2005 Neon.
Old May 12, 2011 | 03:15 PM
mikeeey's Avatar
mikeeey
But to purchase blue LEDs wouldn't require those bases anyway, they would most likely be 1 piece with those bases built in anyway. I'm just trying to find what pc194 is equilivant to for LEDs. I'll try contacting the above website and asking them if 509t is the same fit.
