Low MPG
Old Jun 8, 2011 | 01:08 AM
BryBry's Avatar
BryBry
Thumbs down Low MPG
i feel like im getting low MPG on my neon!! anyone can help me?
Old Jun 8, 2011 | 08:51 AM
leprechaun1874's Avatar
leprechaun1874
We are going to need some details.
What mpg are you getting?
Have you done a tune up (plugs, wires, ect)?
Old Jun 8, 2011 | 06:53 PM
darthroush's Avatar
darthroush
Section Moderator
You feel like your getting low MPGs, or you are? We need more info than "feelings."
Old Aug 11, 2011 | 11:20 PM
mitsubishifreak's Avatar
mitsubishifreak
Default ridiculous mpg!!!
hey guys ! I bought a 2004 r/t neon 5 speed and drove from maryland to north carolina and noticed that im getting maximum like 24mpg or less on the highway going 65mph to 70 mph is very ridiculous! i have change the spark plugs,the wires,coils,fuel filter ,air filter,put new injectors.timing belts and check compression and nothing.!! any suggestions??
Old Aug 12, 2011 | 03:53 PM
darthroush's Avatar
darthroush
Section Moderator
What plugs and wires did you put on? Are the brakes dragging? Tire pressure is good? You are running the required premium fuel?
How many MPG's are you expecting exactly?
Old Aug 13, 2011 | 03:44 AM
mitsubishifreak
I put Bosch Platinum+4 Plugs with new original wires, and regularly check the tire pressure and set it on 35 psi. But i don't put 91 Octane i put 89 Octane. And even though the brakes are working fine im going to check them anyways just to be sure.
also expecting to do 26 to 28 mpg on the highway, cause im doing right now like 21 to 24mpg on the highway ,my girlfriend's toyota rav4 v6 2008 does a bit better mpg that my neon does right now.
Old Aug 13, 2011 | 05:12 AM
darthroush's Avatar
darthroush
Section Moderator
Horrible plugs. Platinums don't go in waste spark ignition systems either, whether they are a single or +4. Put in basic copper plugs properly gapped (factory Champion or NGK Coppers); that'll probably help more than MPG alone. If you don't run 91, the computer will cut back timing and you'll lose engine performance and MPG to prevent engine damage due to the lower than "required" octane. The opposite holds true as well; if you run 91 in the base 2.0L, you can actually lose performance and MPG. Wouldn't hurt to bump tire PSI up to 38-40PSI if you are wanting a bit more MPG instead of overall..."performance?"
Change the plugs and run a couple of tanks of 91 and see where you get IMO. These cars do seem to like a bit higher RPMs as well. I get better mileage going 65-70MPH than 55MPH.
