injector question
Old Jul 10, 2005 | 11:47 PM
neonrt01's Avatar
neonrt01
Default injector question
just wondering if you can take srt 4 stage 1 injectors and put them in a rt model. I have a 01 neon rt that has brand new motor(blew the old one up opps) It is boreded over .20 with ross racing pistons arp rods and bolt comp cam head is is completely port and polished and balanced and blue printed so the motor is isn't not stock also have aem intake and obx header with magnaflow exhaust
so if you can tell me if the injectors will fit i was told that they are inter changable but wanted a second or thrid opinion
thanks
Old Jul 11, 2005 | 03:14 AM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: injector question
yeah but you will need to change fuel map and get a PCM make sure your a/f ratio stays same...remember the Litre flow of srt4 injectors is more than stock like twice the flow. you would need a fuel pump as well. Dont know if stock could even handle the output.
Old Jul 11, 2005 | 08:17 PM
neonrt01's Avatar
neonrt01
yeah i am bidding for a walbro fuel pump that came off an srt 4 so far i got but you know how that goes.
I knew that the stock fuel pump wouldn't be good at all that is the reason i a was so courious the same guy also has the injectors that he took off his to upgrade to the stgae 3
to change the fuel map wouldn't that be something dodge would have to do? or am i mistaken?
Old Jul 17, 2005 | 09:39 AM
RadarLove's Avatar
RadarLove
No way do you need higher flow injectors with those mods. Start looking again after you dyno 200 whp.
