CV joint
Old Aug 28, 2005 | 11:48 PM
MoMagnum's Avatar
MoMagnum
Default CV joint
I have a CV joint that is going, how do I know which side it is? It isn't clicking, just making the steering whell hard to turn at low speeds.
Old Aug 29, 2005 | 03:03 AM
RadarLove's Avatar
RadarLove
Default RE: CV joint
Are you sure it's a CV joint then? Could be the power steering pump... could just be low tire pressure. Just a thought.
Best of luck!
Old Aug 31, 2005 | 06:05 PM
01ACR's Avatar
01ACR
Yeah, Id start at the beginning and check your power steering fluid, if its good, then check your pump. could be a number of other things besides cv joint
Old Sep 6, 2005 | 10:10 PM
ewetho's Avatar
ewetho
Check you strut mounts and ball joints. Notorious around industry for causing stiff steering. (Not neon specific like a known neon problem just general car knowledge) Not common for a stiff steering issue from a half-shaft. So check struff that can get stiff like dry ball joints or failing strutmounts.
