Help with 2005 dodge neon sxt
Old Jan 1, 2013 | 11:13 PM
Naescott2013's Avatar
Naescott2013
Question Help with 2005 dodge neon sxt
2005 dodge neon sxt... Replaced headgasket, radiator, water pump, thermostat, timing beklt but the car is now overheating and making a bubbling sound under the hood. No smoke or anything. Im about ready to give up. Now im thinking I need to check my cooling fans. Any ideas as to what is wrong now??? Thoroughly disgusted!
Old Jan 4, 2013 | 09:32 PM
go-part's Avatar
go-part
Former Vendor
Sounds like you have air bubbles in your cooling system..
With the engine COLD, remove the cap, start the car and let it run for a few minutes, shut it off and wait for about 10 minutes this will allow trapped air to evacuate from the system
Old Jan 6, 2013 | 05:59 AM
darthroush's Avatar
darthroush
Section Moderator
How does the gasket on the radiator cap look? Is the cap itself functioning properly? Might be worth the $4 to find out as you've replaced everything it seems except the cap.
