03 Neon, rapid power loss...won't go in drive...
Old Sep 11, 2005 | 11:09 PM
replicant's Avatar
replicant
Default 03 Neon, rapid power loss...won't go in drive...
I was headed down interstate going around 70 when my Neon just lost power. The lights didn't dim or anything, it just lost drive power. I pulled to the side and killed it. A moment later I started it back up, put it in drive, and it wouldn't go anywhere. While waiting on the tow truck I started it again and it went...but not very far...I was making weird noises and after just a second it lost power again and RPM's went up as I decelerated. Anybody have an idea of what might be wrong with my Neon? Thanks...
Old Sep 12, 2005 | 03:59 AM
replicant's Avatar
replicant
Default RE: 03 Neon, rapid power loss...won't go in drive...
Oh, BTW...It's an 03 SXT with 40K on it. I haven't done any mods to it. I've checked the Trans fluid level and it's fine. I've looked in, around, under, everywhere under the hood and I don't see anything that looks broken or any kind of fluid anywhere...
Old Sep 12, 2005 | 01:46 PM
highrevr/tflea's Avatar
highrevr/tflea
mmmm....fuel pump?????? what noises did it make..?///could be a timing issue too...check your belt
Old Sep 12, 2005 | 03:16 PM
replicant's Avatar
replicant
Well, it starts fine and idles fine...I don't think it's the fuel pump, but then again i'm no mechanic. The most likely thing from what i've found (and I pray this is the problem) is maybe a clogged transmission fluid filter. I'm fixing to drop the transmission pan and get messy and see if that might be the problem...if not I think i'm fixing to drop some big bucks...
