2005 Dodge Neon SXT Oil Pressure Light
Old Jan 30, 2013 | 09:10 AM
TempestRogue's Avatar
TempestRogue
Question 2005 Dodge Neon SXT Oil Pressure Light
The husband had his oil changed last week at the dealership - they said that he had a leak around his oil pressure sensor. He changed out the sensor about a week ago - but today after driving for about 30 minutes - when ever he stops the oil pressure light is coming on then going off.
Mistake in installing the sensor, grime on the connector?? Any ideas where to start??
Old Feb 6, 2013 | 06:13 PM
go-part's Avatar
go-part
Former Vendor
If the dipstick shows a full amount of oil then low oil isn't your problem. The oil pressure could possibly be low because of a worn or broken oil pump, a plugged oil pickup screen in the engine's crankcase,or excessive bearing wear.
Old Feb 7, 2013 | 01:59 AM
darthroush's Avatar
darthroush
Section Moderator
Did he add any extra thread sealant on the sensor? It doesn't come with any decent amount IMO from the dealer. Also, did he clean out the sensor connector? That can get filled with oil when the sensor leaks.
