where can i get a power steering pump cooler?
Old Feb 18, 2013 | 08:22 PM
idriveafastcar's Avatar
idriveafastcar
Default where can i get a power steering pump cooler?
Broke the power steering pump cooler. Where can I get one for a 2004 2.0l base model. Is that a pressure line?
Old Feb 21, 2013 | 01:34 PM
idriveafastcar
guess nobody helps on this site. lame
Old Feb 23, 2013 | 03:57 PM
go-part's Avatar
go-part
Former Vendor
Its called a power steering fluid cooler. It works the same way your coolant system does except it removes the heat from the power steering fluid.
http://www.autozone.com/autozone/par...oler/_/N-93ytp
Old Feb 27, 2013 | 05:46 PM
TejasMtnBiker's Avatar
TejasMtnBiker
You can make one from an junkyard a/c condenser really easy if you have access to that..
here's a cheap one I saw on ebay, same idea
http://www.ebay.com/itm/97-98-99-00-...b37ca1&vxp=mtr
