Tail Light Problems!!!!!
Old Sep 18, 2005 | 01:09 PM
Dj_plutonium's Avatar
Dj_plutonium
Default Tail Light Problems!!!!!
Hey....ive had my euro lights installed for the longest time , since ive installed them my reverse light bulbs have been consistently burning out ......upon an attempt to fix them last nite my genius self decided it might have been a problem with the conductivity so i wrapped a piece of aluminum foil around the base and put it back in the socket!!!! it is was too late to realize this was a bad idea as i would be connecting the positive to negative and then it blew the other bulb as well! I woke up this morning and my rear defrost wasnt workin either now im unsure to as whether this has something to do wit the lite or that the switch for the rear defrost could have come out upon hittin a serious POTHOLE (damn potholes) wondering if ne1 had ne suggestion or comments?
Old Sep 18, 2005 | 03:08 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: Tail Light Problems!!!!!
Check your fuses. You probably blew one or more. If none are blown, check the bulbs. I'm sure you blew at least one if not more.
