95 dodge neon stuck on full throttle
Old Apr 14, 2013 | 12:39 PM
ShawnGeimer's Avatar
ShawnGeimer
Default 95 dodge neon stuck on full throttle
hey got a 95 dodge neon sohc just rebuilt the motor from the bottom up and just installed it everything went great. First issue i had was i had to replace the tps. Now i'm having a issue the when i start the car it's stuck on full throttle i'm not sure what wrong with it cleaned the throttle body and everything please help
Old Apr 17, 2013 | 07:26 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Default clarity
What do you mean "full throttle?" Are you rpm's increasing as soon as you start your car without applying the accelerator? Could be a an unattached vacuum line. visually inspect the engine bat area, specifically from the throttlbe Brady to the cylinder head for leaks.
Old Apr 17, 2013 | 10:45 AM
Topher5150's Avatar
Topher5150
I would check the TPS, I have a car that frequently burns through TPSs and when it does the car will drive it self at 45mph with a screwy idle.
Old Apr 18, 2013 | 12:27 PM
idriveafastcar's Avatar
idriveafastcar
make sure the rubber is not rolled over where the hose clamps hold the accordion like tube from the intake to the throttle body. i had trouble with mine after i replaced my trans. i had to adjust it twice. then it finally ran normal. also a bad pcv valve will cause this too.
Old Apr 18, 2013 | 06:09 PM
darthroush's Avatar
darthroush
Section Moderator
The TPS and intake tube are the two things I'd check first as well.
