Please help! Head Gasket vs. Radiator Issue?
Old Jul 4, 2013 | 04:18 PM
clinnmcneal's Avatar
clinnmcneal
Default Please help! Head Gasket vs. Radiator Issue?
I really hope that someone can help me because I am at the end of my rope here. I have a 2003 Dodge Neon, 143K miles. I drove the heck out of it for years until I moved to DC about a year ago. After that it's been sitting except for occasional use, mostly highway going between DC and Arlington. I am moving back to St. Louis in late August and need to drive the car back when I go.
I wanted to get it checked out because I felt like it was running really rough. I went to Firestone, and they told me that the coolant system was pressurized and that I had a leaking head gasket (leaking but not blown), which they said would cost around $2000 to fix. They also said that I needed new control arm bushings, engine mounts, oil pan gasket, and oil switch, all of which added up to another $2000 in the estimate.
I took the car to a mechanic that my cousin recommended that they trusted and have been using for years. I already knew that the car wasn't worth paying to fix the head gasket, so I bought a bottle of Blue Devil Head Gasket Sealer. The mechanic checked everything out and told me that the control arm issue was bogus, and the engine mounts were a little worn but they were fine and that this was what was causing the rough idle, and it is common for 4 cylinder cars of this type to run like that. He also told me that he wasn't worried about the gasket because it wasn't skipping or blowing smoke, but that we could go ahead and put the sealer in just in case. So we put it in, and after about a half hour of idling the car was severely overheated and chiming the warning chime. We cooled it off and he drove around with a sensor plugged in and said that it was running about 5 degrees hotter than it should just driving in the city at low speeds. He told me that he was concerned about the radiator and I should check it out on the highway. I drove the car home after that and got on the highway for about 30 seconds (on and off at the next exit, but got up to about 50) and it overheated into the red. I have NEVER had problems with the car overheating before. I let it cool overnight and then drove it around the block for about 20 minutes the next morning. The gauge got up past the first mark after about 10 minutes, which it never did before. I called the mechanic and he said that he thinks the pressure in the system was from a blockage in the radiator and the sealant had just exasperated it, but now he thinks we know what the problem is. He told me to take it in next week after the holiday and he'll check it out and probably need to replace the radiator, which he said would only be a couple hundred dollars.
Now this second mechanic came highly recommended and spent about 2 1/2 hours checking out the car with me and explaining things and did not charge me for anything except $50 to replace the leaking oil switch, and he has spent probably 2 hours on the phone with me between 4 phone calls, and never charged me for any of it- so I know he's not just out to scam me out of my money. What I am confused about is that according to him, Firestone was basically just making up really expensive repairs right and left that I didn't need. He says that if we get the radiator fixed I should be able to make it back to St. Louis.
I don't know what to do. My parents will be driving with me in their car, but I still don't want to get stranded on the road in the middle of the drive. Should I replace the radiator and trust him and hope for the best? Should I worry about the gasket that Firestone said was a problem? I can't pay to replace the head gasket- this car is NOT worth it at all. Should I just cut my losses and buy a used Honda to get me back home? I am really stressed out and at the end of my rope here. Can anyone please help me?! - See more at: http://community.cartalk.com/discuss...onfused#latest
Old Jul 6, 2013 | 01:35 PM
sbhawaiian's Avatar
sbhawaiian
I have had dealings with firestone too. First of all did you find out if your head gasket is blown? Did you look at your oil filler cap, rockers, and dip stick for a milky film? That would be oil and antifreeze mixing. Another test is an exhaust sniffer in the coolant tank to check for gas vapors. Many years ago I had a landcruiser and a compression test showed a the gasket was blown between #1 & #2 cylinders.
As for the overheating I had a stuck thermostat on my 00 neon and got the chime to pull over. I replaced the cap and thermostat but your head gasket is a bigger issue.
Good luck.
