CV shaft removal
Old Nov 2, 2013 | 08:57 PM
patwsharon's Avatar
patwsharon
Default CV shaft removal
I have an 01 Neon. I'm having trouble getting the driver's side CV shaft out. I've disconnected and removed everything that needs to be out of the way. Should the shaft just pop out or is there some kind of locking bolt that needs to be removed to allow it to slip free?
Thanks.
Old Nov 2, 2013 | 09:41 PM
sbhawaiian's Avatar
sbhawaiian
Chilton manual:Position a prybar against the inner joint and carefully pry the joint off the transaxle side gear and retaining clip. Do not use thedriveaxle to pull the inner tripod joint. Doing so might damage the inner joint components. Pull straight out on the driveaxle to avoid damage to the transaxle oil seal. Remove the driveaxle assy, being careful not to over extend the inner joint or damage the axleshaft boots
