Removing hazing from headlights
Old Nov 23, 2013 | 09:43 AM
jaye944's Avatar
jaye944
Default Removing hazing from headlights
So I you tubed for a solution to my fading lights, and here is my results.
1> Initial solution was to use toothpaste (I used arm & hammer whitening) and actually it wasnt half bad !
2> Wet/dry with 320,400,600 then meguirs plasix, But I found that the meg's was so hard to buff out (I was doing it all by hand) and didnt give that nice crystal look.
3> I took to the megs with 800 and 3 coats of duplicolor, this was excellant, I can now actually see where I'm driving !
Attached Thumbnails Removing hazing from headlights-b4-after-1.jpg   Removing hazing from headlights-after2.jpg   Removing hazing from headlights-after1.jpg
Old Nov 23, 2013 | 04:55 PM
darthroush's Avatar
darthroush
Section Moderator
Wetsanding is they way to go if 1. you know how to do it and 2. the lens is bad enough! The result looks really good! Nicely done!
Old Dec 2, 2013 | 09:27 PM
jaye944's Avatar
jaye944
linky
