2001 Dodge Neon; No Crank no start
Old Mar 5, 2015 | 05:46 PM
bskt's Avatar
bskt
Default 2001 Dodge Neon; No Crank no start
Where to begin...the car will not crank. I checked the fuses and relays; it appears they are all good. I jumped the starter relay terminal 30 to 87 and the starter engages. There is power to terminal 86 when i position the key to crank. There is no ground to terminal 85. i checked for continuity at the center post of the neutral safety switch and it is good. When i turned the key to on and jumped the starter the car would not start even though there was never a problem before the no crank condition. i tried the key dance to pull codes and got nothing (no response) and the check engine light does not come on at all even when I first turn on the ignition. i am leaning towards the PCM as the problem, but i would like to get a second opinion or two on how to proceed. I do not know how to confirm whether or not the PCM is the problem. Thanks in advance...
Old Mar 6, 2015 | 02:50 PM
Majestika's Avatar
Majestika
I am currently having the EXACT same issue with my '01 1500. It's pissing me off. If you happen to figure something out, please post an update.
Old Mar 6, 2015 | 05:54 PM
bskt's Avatar
bskt
Will do...
