Neon pcm help.
Old Aug 9, 2016 | 12:40 PM
Friz1996's Avatar
Friz1996
Default Neon pcm help.
I have an engine out of an 03 neon that I am putting in a jetski, yes I know I'm crazy. I got the motor in with few issues, but when I went to hook up the pcm that's when the trouble began. Finding the pin in Info and general wiring I for for these has been near impossible after days of searching. I have a pcm and harness out of an 03 with the key and security module and also one out of a 99 with the corresponding harness. I'd like the easier method of hooking these up to make the motor run. The engine is wired in. I just need to know what needs to be hooked up to pcm and what wires need to be hooked where to make the engine run. I don't need anything like alternator or transmission. Just engine. Any help would be much appreciated as this is my last resort. Even if it's only a pin in diagram.
