Low beam problem...HELP
Old Apr 25, 2004 | 04:53 PM
az3rch's Avatar
az3rch
Default Low beam problem...HELP
I have a little problem with my low beams. They were working and then all the sudden they just stopped (of course at night too). I have a Neon 2001 ES. Here is what I have done.
1. Popped out the current headlight and checked it with the original ones that were in there when I bought the car ( i have some sylvania lights in there now)
2. Checked all the fuses.
3. The high beams, turn signals, parking lights, and the dash lights work.
HELP. I dont have a manual so I dont know if there is a hidden area for another set of fuses.
Also...anyone in Harrisburg area, PA, could you recommend a good low price mechanic to look at this?
Thnx.
Aaron
Old Apr 26, 2004 | 01:39 AM
97neon's Avatar
97neon
Default RE: Low beam problem...HELP
did u check the wire connections? it should be that or a fuse. or it could also be in the dimmer switch.
Old Apr 26, 2004 | 03:21 AM
techmanbd's Avatar
techmanbd
not sure what fuses are for what, but there are a set of fuses under the hood next to the battery, and when you open the driver door there is a panel on the side of the dash
Old Apr 26, 2004 | 02:23 PM
az3rch's Avatar
az3rch
@techmanbd
Can you be a little more specific as to where this panel of fuses is on the inside of the car. I know about and checked the ones by the battery, but didnt know about anymore.
thanks
Old Apr 26, 2004 | 03:21 PM
techmanbd's Avatar
techmanbd
Ok, when you are sitting in the driver seat, open your door. look on your left hand side of the dash. There will be a panel that says fuses on it with what looks like a place for you hand to grab on. grab and pull out. The driver door has to be open because it covers the access panel to the fuses
Old Apr 26, 2004 | 10:20 PM
az3rch's Avatar
az3rch
I checked every single fuse. It is on both headlights. I made an appointment with dodge so we will see.
