Help! P2035 Trouble Code. Can't solve
Old Nov 21, 2021 | 09:04 PM
Yellow-submarineSXT's Avatar
Yellow-submarineSXT
Default Help! P2035 Trouble Code. Can't solve
P2035 Code
2003 Dodge Neon SXT 2.0l SOHCHere is everything that has happen up until this point.
timing belt broke. Replaced and is running. Lined up timing marks top dead center on compression stroke Car lot drove fine. Out and about after about 1/4 mile to a mile p2305 pops up and it feels like car has gone into limp mode. I love this car. It was a hand me down from my dad. I have replaced many things already just because and also a few things to try to fix this code to no avail.
New PCM. New catalytic converter.New plugs and wires. New coil pack. New cam shaft position sensor. New upper heat 02 sensor. New down stream 02 sensor. New fuel rail. New injectors. Re-did all grounds.All ground clean to my knowledge even ground strap. New battery new battery post connectors. Could my timing be off? Could it be crankshaft sensor? I don't know what's causing it but I could really use yalls help
