Steering wheel install? Come on I know someone knows...
Old Jan 24, 2006 | 02:39 AM
neon2_0t's Avatar
neon2_0t
Default Steering wheel install? Come on I know someone knows...
How do I install an aftermarket steering wheel on my neon? The dealer didnt seem to want to help me on this question.
Old Jan 27, 2006 | 11:07 PM
colton_levi's Avatar
colton_levi
Default RE: Steering wheel install? Come on I know someone knows...
Crack out the repair manual and get to work. It will go through step by step how to remove your stock wheel. Then, depending on what aftermarket wheel you buy you may be able to just bolt it right on. Or you may have to utilize an adapter plate. The dealer probably wouldn't help you because Dodge sees removing the air bag from the vehicle a safety issue. Which it certainly is, so you might also want to invest in some new seats with a 5 point belt so you won't be eating your fancy new steering wheel when you rear end the grandma that slams on her breaks to avoid running over a squirrel standing in the road that's not really a squirrel, just a dark spot on the road, but she doesn't know that since her eyesight is so bad.
Old Jan 28, 2006 | 12:37 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Well said......
Dusty
