Engine Idle Undershoot
Old Feb 22, 2006 | 09:52 AM
hwkdrvr's Avatar
hwkdrvr
Default Engine Idle Undershoot
2000 Neon SE: Sometimes the engine runs really rough when idling and the vehicle is in drive. I can put the auto tranny in neutral and the rough idling/shaking will stop. Has anyone had this problem? If so, have you taken it to the dealer for a computer software update?
Thanks in advance.
M.
Old Feb 22, 2006 | 01:48 PM
casper's Avatar
casper
Default RE: Engine Idle Undershoot
Could be a few things. When was the last time you did a tune up? Wires, plugs, air filter? Also could be the IAT sensor.
Old Feb 22, 2006 | 02:24 PM
whyte69's Avatar
whyte69
IAT = Intake Air Temperature Sensor
Old Feb 22, 2006 | 10:49 PM
hwkdrvr's Avatar
hwkdrvr
I tuned it up approximately 2 months ago. New wires, plugs, air filter. Two days ago I changed the oil, tranny oil and filter. I try to take good care of my cars. I bought this one used. I did some checking and apparently there is a TSB for the symptoms I have described. I was wondering if others had experienced this phenomena and if so, what their solution was.
M.
Old Sep 8, 2009 | 05:48 AM
butsog29's Avatar
butsog29
Default hello!
im new here and im having the same exact problem you had a while back w/ your car idle problem. just wondering, if you ever find out what is wrong with it? thank you...
Old Nov 1, 2009 | 06:36 PM
jmja9281's Avatar
jmja9281
Default Hola !!!
I had this problem a few days ago with my 2004 Neon SXT, I noticed a vacumm line was not properly seated. I Corrected it and the vibration stopped. Hope this Helps
