alt. flies off at high rpm shift
Old Mar 15, 2006 | 04:13 AM
leathal neon97's Avatar
leathal neon97
Default alt. flies off at high rpm shift
I went though 4 belts in three weeks it usually happends i first and second gears. I tried all different tensions. are there any belt up grades? Ive been using cheap 8 dollar ones. all I have only bolt ons clutch and fly wheel. I found one of the belts and it is still in new condition. am I doing Some wrong or do other people have this problem because changing altinator belts on a regular basis is a pain in the a$$
Old Mar 15, 2006 | 06:12 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: alt. flies off at high rpm shift
I had my power steering belt come off on my R/T once after hitting the rev limiter, but no belt problems other than that.
Old Mar 15, 2006 | 06:16 AM
highline95jl's Avatar
highline95jl
You probably have the thing too tight on there, loosen it up a bit, and dont use cheap ****, with car parts you get what you pay for.
Old Mar 15, 2006 | 06:26 PM
casper's Avatar
casper
Never really head of that. I would go with a better belt and see what happens.
Old Mar 15, 2006 | 06:43 PM
leathal neon97
what kind of belt would you suggest I always thought a belt was a belt I found my last one and its still in prefect condition
Old Mar 15, 2006 | 09:02 PM
RadarLove's Avatar
RadarLove
Is the alternator loosened up after this happens? Have you watched it running to see if one of the pulleys is out of line? I know that this has happened with some guys that don't get their new UDP lined up quite right.
Old Mar 16, 2006 | 10:56 PM
leathal neon97
no everything is lined up correctly and I used a paint stick to ceck if it came loose and it didnt I took Highline97jl's advise and loosened it up a bit I put the belt on loose and tightened it while the car was runing untill just a couple turns after it stopped squeiling and i hope it works its been a day in a half and no problems so far and Ive been pushing my car hard
I even raced an srt4 last night for the hell of it to test my belt situation and I wallked all over it It was boned stock except for a boost controller and the driver was inexperieced but he talked the talk and I thought I was going to loose for sure so i didnt put money on it. he even offered to through down pinks but better be safe than walking any other driver and i would have been but after i won im kicking my self in the a$$
Old Mar 16, 2006 | 11:16 PM
spudsterier's Avatar
spudsterier
be careful what you say about beating an srt-4....alot of people wont believe it...and throw a fit
Old Mar 18, 2006 | 04:31 AM
leathal neon97
You missunderstood I wasnt bashing the srt4 what so ever I have total respect for the srt4, but with out the right driver its useless I seen an old 70 year old couple driving an srt4 the other day man that in my mind is a waste in my mind no offense to the elderly
Old Mar 19, 2006 | 04:07 AM
98Neon4Door's Avatar
98Neon4Door
your sure it was the srt4 and not the lookalike wanna be that dodge made?
